T3/T4 Hybrid Turbo?
SDtoyomk3
46
san diego
i found a guy selling a brand new t3/t4 hybrid "p" trim turbo for 4bills. i was wondering if it would fit my 88 7mgte turbod supra?
MKIIINA
Destroyer of Turbos
Plano, TX
if the flange is the same as the ct26 youll be ok. if not you could get a cheap ebay mani.
without looking at the turbo thats the best i can do. my brother runs a t3/t4 hybrid and its a bolt on affair. YMMV
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
That would not be a bolt on. Looks to be T4 flanged to me although I could be wrong. You can get T4 exhaust manifolds off ebay for pretty cheap.
MKIIINA
Destroyer of Turbos
Plano, TX
exactly now that ive seen it. its a divided t3 housing. get a cheap ebay mani, new dp, wg, dump tube and that should be a pretty fun turbo
edit: stupid fingers....
Doward
4,245
Alachua, FL
That's a divided inlet T3 flange. You can't bolt that to the ebay mani - but you CAN build an adapter to let you use the ebay mani.
If you wanted to really cheap out, use a stock turbo mani, and built an adapter.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Thats a divided T3 not a t4
He doesnt specify if the P trim is hot or cold side, but if thats hot side its very similiar to mine although my turbine is .63AR
SDtoyomk3
46
san diego
i didnt understand a word of that.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
lol, I wouldnt have either about 6months ago.
Basically, the "hot" side is what spins from the exhaust pressure. the "cold" side is the part that makes the power (well thats a simplified way to look at it). As for the numbers I was just saying that it was similiar to my turbo and I am happy with mine.
Doward
4,245
Alachua, FL
The P trim is a designation for turbine only ;)
A turbo is an exhaust-driven fan. The exhaust side has a fan that sits in the exhaust, and it spins. It is connected to a shaft that goes to another fan that pulls cold air in, and compresses it.
935motorsports
San Diego, CA
You can buy a housing that will let you bolt that turbo to the stock manifold.
I wouldn't buy it though, unless it had some receipt. Buying turbos from 3rd parties is always scary. It could die in a week and you would be screwed.
Be prepared to spend an extra $200 on the custom housing with internal wastegate, and $100-$150 for custom oil lines.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
huh, I did not know that. Excuse me for showing my turbo ignorance. Trim numbers I have grasped the concept of. Trim letters never actually made sense to me, at least until I read your post on them in your section :)
OK so a Letter trim is sometimes used to designate the turbine wheel and its always a number for compressor. Got it, thanks.
