Switchable BOV's?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I just bought an Mk3 with 350+ RWP that has the Porsche recirculating BOV. Is it possible to install an to-atmosphere style BOV like a HKS or Greddy but have the ability to choose which BOV I want to run? Anyone ever tried installing both types but having a manual valve to shut one off and run the other? How would this affect the tuning? I just like the idea of playing with the sounds and performance of each type. Any feedback would be great, thanks.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Unless you want to be able to switch it on the fly from inside the cabin... :)
Actually, on second thought, I'm not too certain this would work properly. I seem to recall that many BOVs use the vacuum source to help stay closed and prevent boost leaks, so removing the source from one might make it more prone to boost leak...
GotBoost?
I do
Nov 25, 2005
318
By My Computer
I've run the stock bov along with the greddy bov, to reduce backfiring. It worked. But i can see problems with your idea. The ecu adjusts for your setup (to a point), but the moment you switch (per your idea), the ecu gets thrown off by the change, and yer 350hp supra is going to go off tune and running rough.
