Swapping Stock Boost Gauge for Stock Volt Gauge
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Has anyone done this mod after installing an aftermarket boost gauge; in lets say a guage pod; and replaced the stock boost gauge with the stock volt gauge?
What I want to know is how you hooked up the volt gauge, did you use existing contacts points on the printed circuit or did you just run a wire from the gauge to a 12 v source so the gauge reads voltage all the time, or a switched 12 v source
Thanks
Wayne?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
It's been done before numerous times. It fits right in the stock location with no modification necessary. All the electrical hook ups are there. Plug and play.
I'm sure if you do a quick search you'll find some more info on it
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
hrm...plug + play = good
broken boost gauge + working voltmeter = :bigthumb:
shaeff
Kurt is FTMFW x2!!!!
10
Around
Thanks
Wayne?
i'd be more concerned with figuring out what your name is... :icon_razz
-shaeff
jester1341
topless and blown
Western Maryland
question i know this was forever ago and i read a similair post a looooong time ago might have even been when i was stupid enough to hangout on SF, but i digress....
i did this thismorning.....result....my volt meter is a boost gauge measureing Volts....:scratch: as i push the gas the volt meter goes from 0 up to around 12 volts and when i shift gears it hits 0 again.....
my question is how stupid do you have to be to screw up this MOD??
john
SPD TRP
Apr 12, 2005
526
Katy Texas
john
Slept alot since then and drank many beers too, but here goes---there is a spot pretty close to the stock boost gauge that says +, hook the + terminal of the new 12v gauge to there, then follow the trace on the printed curcuit to a ground and hook up the other terminal on the gauge to there. I did this mod and mine works perfectly. Turn the key on and instant voltage reading, turn it off and back to zero. Hope this helps you, been a while since I did this mod, can't remeber everything, but it isn't hard to do.
Good luck.
Wayne
jester1341
topless and blown
Western Maryland
i observed my NA cluster and saw there was an extra 'box' on the turbo and realized it is sending the boost signal to the contacts on the cluster...i removed the 'box' entirely and hooked the voltmeter up the same way it is on the NA cluster......i expect it to work now
thanks,
john
