Swapping in rebuilt motor
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
Im picking up a rebuilt motor tomorow to swap into my 86.5 and i want to know what i should replace while i have the engine out? Also where can i buy an alignment tool for this clutch?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
autoparts store should have the clutch alignment tool.
i would change the front and rear main seals, along with the oil pan, if it leaks.
other than that, you could get all of the other gaskets when the engine is in if you dont wanna have it out for a while
AJ'S 88NA
2,419
Florida
What are you getting with the motor? Is it a rebuilt long block? Usually should put a new water pump, oil pump, of course plugs.
cuel
1,536
Baytown, Texas
All tune up components(plugs, wires, cap, rotor), timing belt, t.stat,, all the rubber hoses at the back of the head, all the seals under the timing belt(cams, front crank, oil pump shaft), and any other hoses that look worn- especially coolant hoses.
