you will need the clutch and brake pedal, master and slave + lines and driveshaft (or atleast the front half).
the neutral saftey will need to be bypassed and revese light switch wired in.
the auto ecu will run the 5spd fine aswell.
you will need the 5spd speedo cable aswell, its about 1-2 inches longer, as the speed sensor is 1-2 farther back on the tranny.
on the 87 the firewall holes are pre-cut, so it will be a literal bolt in swap. also if your car is ABS, make sure the tranny is from a abs car, or you wont have the rear speed sensor. abs sensor is the same 87-88. 89+ is different (plug?) according to my interchange books.
