Well I purchased a 7mgte that just got rebuilt. I got it for a good price and needed a motor asap because this is my only car and I was moving in a few days. I got the long block and everything looked good it has a mhg and arp studs. He claims that the crank was cut and new bearings were installed. Well I swapped in the motor and everything seemed fine. I was obligated to drive about 230 miles to help my girlfriend move her stuff out and another 250 miles to our new home. I had no other choice but to drive the supra the day after i swapped in the motor.
Well the only problem I have is the oil pressure, after the oil fully warms up at 2500 - 3000 rpms the pressure is only slightly above the 20 psi mark, I'd say somewhere between 25-30 psi. I was running 10w30 and didn't like the oil pressure so I pulled off the highway and bought some 10w40 and changed the oil in a parking lot. The 10w40 is still the same just above the 20 psi mark at 3000 rpm. I was worried about the low oil pressure but it made the 500 mile trip split into two 250 mile drives just fine.
So I have looked around and it could be the valve that opens at 40 psi in the oil filter head is stuck open. If I start the car with the line to the oil cooler off nothing should come out until it reaches 40 psi correct? I am going to try this first, Anyone have any other ideas?
