okay,took some time to compile all these photo's,but here it is!
Started off by making the top template to house the subs,had to trim it to fit under the the back of the rear seat-back.It took some time,and a few screw-ups,but got it done.Made the sides to fit,and the front. More time,more template's and F ups. Final result looks good!
Tranny hump fits dam tight!After I got all of the top pieces cut and fit,I screwed them all together using wood glue.This is the top,2 sides and the front.
I chose Audiobahn's Alum12Q's,around 1 cubic ft of air space.
Here's the most important step,I needed something to keep the fiberglass from sticking so I could remove the NEGATIVE underside of the box.I used good 'ol duct tape to seal off any of the origional floor pan.I was tempted to use a releasing agent,hell Pam would have worked I guess!
