I don't know if this is normal, but one of my two front springs is ~0.22 inches taller than the other one. The rear ones are identical at about 1ft 0.6inches in length. Does it matter which side I put the front taller spring? I was thinking the driver side since it sees more weight? :dk: Also, can anyone confirm if these are TRD Supra TT Springs or stock OEM ones?
Shorter Front Spring:
Taller Front Spring:
Both Front Springs:
Both Front Springs:
