MADE YOU LOOK What's up guys, the name is Jack and I drive a 97 Nissan 240sx (my 5th 240) and an 89 supra with plans of putting a 1jz vvti in the 240sx. It's a bit 4x4 status and weak wheels at the moment but i have nismo struts and tein springs to install for a good ride and will lower it about 2". I've worked at several dealerships and performance shops as a fabricator/mechanic and do all my own work on my car, as most of you do. I have found it rather difficult to get a decent 1jz vvti manifold for a good price, so i'm going to end up having to get the 500 dollar one off ebay and brace it/grind the slag out, i may even re-weld it all. As of now plans are a p6262 billet turbo, 2jz 550 injectors and 93 pump gas. I do plan on making a few copies in higher grade stainless though. Anyways, just thought i'd say hey. Also, yes that is an mk3 supra beside the 240. If any of you have any suggestions/info for me since i'm a noob to the jz's then let me know. Also, yes my mk3 has a blown headgasket, and uses about a quart of water every couple days, so add that to every other one.
