supercharged supra
Mr.SelfDestruct
I build planes... yeah...
May 27, 2005
608
everett, WA
dense air in england... I'd almost prefer a turbo, but if you supercharge it, use the 7m-ge, higher compression=more HP w/ less psi. I dont know of any kits, or anyone who has done this... either way, good lusk w/ your endeavors.
ps: before you do anything I would reccomend a metal head gasket, and some hrp head studs torqued to ~72ft./lbs.
Anomili
Obsessed
Apr 9, 2005
371
In an Igloo
Hmmm a supercharged 7M. Seems to ring a bell, but if it did ever happen it was only one person and it must have been way back in the day. (Aka. I can't remember.) Good luck though, you'll definitely be doing some "minor customizing."
Dave
MKIIINA
Destroyer of Turbos
Plano, TX
there was a guy who had mocked up a SC on a 7m but it didnt look like it would work well /wasnt finished. could be interesting....
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
It can absolutely be done. Most people go Turbo because swapping in a turbo engine is cheaper... by a LOT. Putting on a supercharger would mean a whole lot of custom fab work, and a whole lot of R&D.
bkma71
supra coupe
Jun 7, 2005
91
troutdale, Oregon
there was a topic somewhere about using a supercharger from a old 5gze(?) mr2 but I believe it was determined to be to small to flow enough. I would say use like the trd supercharger made for the new thundra's depending on what type of supercharger you plan to run. root, centrifigal. whatever there is deffintly someway or another to get a supracharger on there if someone really wanted too.
Mr.SelfDestruct
May 27, 2005
608
everett, WA
you're thinkin about the 4agze, and yes, the sc off that would be far too small to even compare to a ct-26. and IMO, the centrifugal sc is the way to go for a supercharged vehicle.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
its been done. but i've only seen one picture. it is indeed possible, probably more easily done with a centrifugal unit from vortech or somebody else...
here's the picture of the only one ive seen. it's a roots-type, and if you are an experienced welder, or know someone who is, it probably wouldnt be that hard to fab up....
