Summer Daily Driver Build
Supra0089
367
New Hampshire
Hello everyone. The goal with my supra is to build a 400+rwhp daily driver for my summers. The supra has to be reliable because I drive about 100 miles/day, and so I don’t want to go crazy with mods, but I want it to be enjoyable for my spirited driving style. Being in NH, most of the roads I drive are a compilation of winding roads, with plenty of passing zones.
I bought the car with a blown head gasket and an abused motor with a near dead turbo about 4 years ago off of the second owner who lived in South Carolina. Somehow, I was able to drive the 800 miles home without it dying (only overheating 2x). Since the motor was unfixable, I bought a remanufactured 7M-GTE motor from Toyota with a ton of new parts (hoses, wiring, gaskets). The rest of the car had 92k miles on it. Since then I have slowly built the car, trying to do it right the first time without putting the turbo/motor at risk. I’m going for drivability, and longevity with this one.
Engine Performance Modification Summary Year to Year:
2007
o 50 Trim CT-26 Turbo (no longer installed: see below)
o K&N Filter Charger Cone Intake System
2008
o 3” Option Import Divorced Dowpipe
o 3” Random Technology High-Flow Cat
o 3” HKS Turbo Dual Exhaust (Resonator Eliminated)
2009
o Porterfield performance brakes/rotors
o HKS Metal HG
o ARP Headbolts/Studes
o TRD Timing Belt
o Piller Pod
o AEM True Boost Gauge
o AEM Oil Pressure Gauge
o AEM True Boost Controller
2010
o AEM Air/Fuel Ratio Gauge
o XO2 Spearco Front Mount Intercooler w/ 2.5” Core
o LIPP 2.5” IC hardpipes
o HKS SSQV 3 BOV
o DCP Transmission Oil Cooler w/ Electric Thermostat Fan
o Custom Oil Stainless Lines
o Tomei Type S Fuel Pressure Regulator
o Walbro 255 Fuel Pump
o AEM Wideband
o Stainless Fuel Lines with B&M Pressure Gauge
o Lexus V8 AFM
o RC Engineering 550cc Injectors
o Removed A/C
o Greddy/JEGS Oil Relocation Kit Combo
o Shimmed automatic transmission 1/2 & 2/3 accumulators (quick shift mod)
o Built a340e Tranny with Raybestos Blues, Torque Converter, Moderate to High Stall etc etc...
2011
o JT62 P-Trim Turbo
o 4" Polished Stainless Turbo Inlet Pipe (afm delete)
o VPC (no longer installed, see below)
o SAFC 1 (no longer installed, see below)
o Black Coated Valve Covers
o Power Steering relocation
o Tune to 11.5 max a/f
2012
Parts Installed:
o Eagle Rods
o Wiseco Pistons
o Cometic HG
o ARPS
o King Bearings
o AEM EMS
o Engine Bay Respray & a Semi-wire tuck
o Powdercoated Intake Manifold
o Stoptech brakes/rotors
o Goodridge Performance Brake Lines
o Energy Performance Polyurethane Upgraded Front and Rear Suspension Bushings
o TRD Radiator Cap
o TRD Oil Cap
Dyno, August 8th: 387rwhp at 15psi. Estimated current power, 410-430rwhp at 19.2psi
2013 Modifications:
SupraStick full a340e automatic transmission control (transmission stand-alone)
Exterior Modifications/Restoration
2008
o JDM Bronze Tinted Windshield
o JDM Tail Lights
2009
o Sport Tuning 18” 5 Star Rims
o Goodyear Eagle GTs
2010
o Eibach Pro Springs
o Koni Shocks
Interior Modifications: 2008
o Pioneer 5100 series Deck
o Alpine 400watt mono Amp
o Alpine 240wattx4 channel Amp
o Polk DB Series Component Speakers (custom speaker brackets)
o DB 4 1/2" Polk for the Rear Speakers
o 12" JL audio Sub custom fit and built into the trunk (see pictures)
Future Plans:
T4 manifold with a PTE 64/66 Turbo and 1000cc's - Going for 600rwhp
Dyno: May 26th, 2011 (on old setup)
402whp/408trq
93 octane, 90 degrees/90% humidity
Turbo at 16psi
Pictures updated 2012:
Pictures from 2010:
with new suspension
Gauges
Tranny Oil Cooler w/ electric fan mounted under driver headlight
2010 mods: piping, afpr, intercooler, bov, hoses etc etc
a/f gauge where cig lighter was...
XO2 Spearco Replica
Cockpit
Backshot
I'm looking to do bodywork and repaint next winter (Dec 2011). I am considering some body kits...but I want to keep it really close to stock so nothing major.
Perhaps the MA70 front lip from Suprasport: http://www.suprasport.com/JDM-MKIII-..._p_705.htmland
Kiminari Sides: http://www.horsepowerfreaks.com/imag..._Supra_LRG.jpg
With the stock rear bumper. Any feedback?
THE BELOW ATTACHED PICTURES WERE FROM 2009
Supra0089
367
New Hampshire
integra08;1338324 said:
Definitely a sweet daily
Thanks. It's not bad now as it is, but I want to further impress all the other local Subaru/Mustang/Honda tuners in the area...and have some additional performance to keep up with my brother's MK4 when we do our mountain circuit runs. Plus I love working on the Supras.
Supra0089
367
New Hampshire
integra08;1339143 said:
So are you going to build that motor or do a swap?
I'm going to build the 7m that's in there. The engine is basically brand new. I was torn in doing the IJ swap in the beginning, and decided to stick with the 7m mainly because I never had big interests in going over 350/400hp.
Supra0089
367
New Hampshire
Hello everyone. I just ordered up a bunch of parts....and will install them next week unless any red flags are raised.
Here's what's going on the car next week:
HKS 2.0 Stopper Gasket and ARP's
Here's what's ordered and will be put on next week as well:
AEM Oild Gauge
HKS Fuel Cut Defender <<Edit: decided not to go this route>>
Here's what I plan to do:
Install the 3 ordered parts, set boost to 12psi and leave until next set of mods...
Here's my questions:
Is the Fuel Cut Defender Okay to put on as long as I don't boost past 12psi
Am I alright with doing all this without a tune?
Any red flags with this setup?
Thanks!
integra08
145
Florida
Sounds good. I'm more a fan of the 1j but thats me and you stated the engine is basically new so you should have a good base line for a build and 350 shouldn't be a hard task to get to with that motor so glw the build
Supra0089
367
New Hampshire
Thanks, will probably need some of that luck! HAHA
Supra0089
367
New Hampshire
nerfkhat;1350617 said:
Whats a jdm bronze tinted windshield?
It's the Supra windshield that is dark toward the top, and fades lighter as it gets into the vision of the driver. From what the dealer said, it was an option for the turbo car, and costs the purchaser an extra 2k at original purchase.
There are none in the U.S., I ordered one from Japan and the whole $4500 was covered under glass insurance lol. At the time, it was insured as a special interest vehicle, and basically anything that happened to it was 100% covered by the insurance company.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
sounds like a good insurance plan...
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
look killer you have around the same goals im aiming for.
althought i do recommend a wideband in the near futuer just to moater the AFR
Supra0089
367
New Hampshire
BoV install incorrect:One of the members said the BoV is installed incorrectly. I'll be looking into this...prob switch vaccuum lines etc etc. On testing, it does not seem to let out air when engine is given throttle. The picture below shows what the recirc valve is hooked up to. Any quick suggestions or whatever are welcome while I trouble shoot this minor thing.
Supra0089
367
New Hampshire
Yeah it was Liberty Mutual insurance plan I grandfathered into via marriage. They don't do this policy anymore unless you maintain the policy.
It worked out for me in this case, saved me thousands of dollars...
The goals are still the same...although I have been working on doing the necessary upgrades to the auto tranny before I start pushing the psi much above 8 (although I have pushed 10 on the highway a few times...oh well). The tranny cooler will probably wait until this winter for when i take off my bumper for the new FMIC and piping....
The power mods should be finished by next year, then I'm working on some final maintenence things and the interior, then I'm going to do the body and have a repaint...only if I had the cash to do it all now...but I now have my first baby on the way...i forsee this project slowing down after my first is born.
Supra0089
367
New Hampshire
This year's project updated (see first post for bolded info and pic links).
I have to say, with the Lex/550's/afpr/wideband upgrade, this car really is a beast. I can almost (almost to the point where he doesn't just pull away that is) keep up with my brother's BPU 97TT (440whp). Running 14-15 psi atm until I get MAFT Pro or SAFCII to tune.
---------- Post added at 12:10 PM ---------- Previous post was at 11:58 AM ----------
Now my 2nd gear on the a340e is slipping...
I'm looking into local Tranny Shops and doing research on a built tranny. This is a daily, so going GM 3 speeds (TH350 or whatever) is not ideal. I am thinking of Import Performance Transmission Kit or Tranny replacement (http://www.importperformancetrans.com/toyotaauto.shtml). I'll let you know what I figure out within the next month or so...
I've also been thinking about body kits. I want to keep it really close to stock so nothing major.
Perhaps the MA70 front lip from Suprasport: http://www.suprasport.com/JDM-MKIII-Supra-A70-Spec-G-Lip-Spoiler-Body-Kit-_p_705.htmland
Kiminari Sides: http://www.horsepowerfreaks.com/images/products/Kaminari/Body_Kits_MKIII_Supra_LRG.jpg
grifter679
74
San Francisco
skip the safc, and go with the maftpro, ditching the lex afm in the process definitly helps with getting car to run better, with the maft you wont need to really worry about boost cut, I was running 18psi daily and boost creeped upto 22 psi here and there. the speed density conversion was great and after you tune your throttle trim you will have a pretty snappy throttle. You can do so much more with the maft than safc, and for all of the work of wiring in a safc just wait it out till you go maftpro
Supra0089
367
New Hampshire
Good advice. I've lined up the Maft Pro for the spring and the best tuner in the region. I'm shooting for 370whp at 18psi on the 50 trim CT26. After talking with Aaron at DM, I might very well upgrade to a 57 trim to jump the final leg to 400whp on lower psi and a conservative tune in 2012.
TurboLag
26
ILLINOIS
so do you drive her in the winter? worry about rust?
Reading>me... Summer daily. Anyway, worry about rust?
