My 89T is having a intermittent stuttering issue that I think is fuel related but I would like to get your opinions. The problem occurs occasionally during normal driving under 3K rpms & occasionally during idle at stop lights. Example of whats going on; as I'm driving 45-50 mph the car will start to stutter (very slightly buck like a minute form of fuel cut). It will do this for 5-10 sec then clear up as fast a it started. It has does this with me doing 35-65 mph under 3K RPMs. When this happens on the highway I accelerate & get into boost slightly & it goes away. I have not had any problems while in boost, at 3/4 to full throttle, just in the lower normal driving modes. Also driving on the side roads going 35-45 when I stop at a light the rpms rapidly bounce from 600 to 1000 rpms & the car stutters as I'm accelerating from the light then clears up. For the next several miles & several lights I stop at the idle is a smooth 650 rpms & acceleration is smooth & normal.
Im Only at BPU+ Mods Are: Lexus AFM, K&N FIPK Custom IC, IC Hardpipes, 3" Exhaust, Blitz Spec S, Greddy Boost, A/F, & EGT Gauges. Deleted the FPD
I checked & there aren't any codes. Ths ISC is working (it clicks when engine is turned off) The wiring & connections at the TPS, ISC, CPS, & AFM are tight & in good shape. All the grounds on the wire harness are clean & tight, didn't see any vacuum leaks & vacuum is at -19 to -20 on the boost gauge at normal idle but it does jump around when the rpms bounce. I cleaned the air Filter & replaced the plug wires with new NGK's. I'm leaning toward the stock fuel system but not sure where to start. Pump, FPR, Inj, filter, ???
Your input is appreciated
