Hi! I have a 1990 JDM RHD 1jz Turbo R.I am wondering if there is any way to see if the tranny has stock clutch without dropping the tranny? and would oem toyota clutch will hold about 330ft-lb torque?
here is my setup
1jz-gte w/ trust cone filter, trust 3" cat-back, 3" down-pipe, high-flow cat, blitz bov, and boost controller......
with this setup, and if I run 1.2bar (~17psi), does the oem clutch able to hold that power if I floor the gas sddenly?
Thanks for all ur help, I tried to search, but only thing I found is that the r154 can hold alot of power w/ stronger clutch, but how bout oem?? no one ever mention it???
Note: I don't race, I just drive a bit over speed limit, but sometimes I like to play w/ 350z, G35 for fun........
			here is my setup
