stupid electronics!!! plz help
turbotrev
Goin WEEEEE on my gsxr600
Aug 7, 2006
311
Clinton, MO
OK, i just got done putting everything back together after a complete rebuild and everything was working fine and dandy before i started the rebuild. So now my fuel pump wont work it wont even come on. Ive checked everything resistance, Ohms, and what not and nothing. Ive search everywhere and looked though every troubleshooting things everywhere.
Im about to pull the fuel pump(walbro 255) and check that on a seprate pwr source.
would having it up on jack stands(front only) have to do with any of it and is there an inertia switch on these cars and where would it be located if there is one?????????:1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp: :1zhelp:
thnx in advance
trev
Bondango
Supra Specialists Ireland
thnx in advance
trev
Fuel pump relay? try bridging out the FP and B+ terminals in the diagnostic plug with the Ignition switched on and check if the pump comes on
turbotrev
Aug 7, 2006
311
Clinton, MO
ahhh i c just to get this down its:
battery hooked up, Key ON, and jump the FP and the B+
this would tell me that the relay is bad or the pump is bad right???
what would i do to check to see if the Fuel Pump Resistor is bad????
thnx trev
