Ok, I've had my rebuilt 7m up for about a week now. Ive had various issues but the one I can't seem to fully correct deals with the car bogging below 1500rpms or so. When the new motor went in, I also put in an R154 so the issue is a bit more noticeable. To describe how it bogs, I'll be attempting to take off in first and the car barely crawls forward. I can have the throttle wide open, boost gauge showing about 2 psi and it just won't move. Then sporadically it will whip back to life and pull smooth and rather hard to 3000rpms+.
Now the odd thing is, it shows no real pattern. At first I believed once the car warmed up and dropped out of closed loop it would act up, but now Ive had this issue occur sporadically after the cars been running for much longer than usual (the point where I'd think the issue would pop up sooner.)
What i've done/checked:
-Can't find any intake leaks.
-Had TPS tested out and adjusted properly with feeler gauge and Ohmeter/voltemeter.
-Base timing checked and set at 10degrees
-New tank of 93.
Also, the issue never seems to occur at night...whether that means anything at all or not, I don't know.
Any help is appreciated, even if its something easy/obvious to you. :1zhelp:
-Steven
-New tank of 93.
-Steven
