Stuck steering intermediate shaft
limequat
Dissident
Detroit
My steering intermediate shaft has been disconnected for a while now. I had it off to drop my crossmember. It has now fused itself in the fully collapsed position.
Is there a trick to coaxing the turtle out of its shell?
#04
526
Cambridge
there is a specific orientation for the two pieces as well as distance apart, I'd suggest starting with measuring a un-tampered with one,
but yeah, they can be coaxed with a fairly large hammer into original place, you may want to use a mallot or block of wood to avoid damage..
#04
526
Cambridge
^yep, forgot about the plastic rings w/bearings that are in the sleeve... of the larger section onto the slimmer section...
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I had one come out on me in the middle of a turn at 45MPH a few years ago. Mine stuck "turtled" as well. I had to remove it completely, put it in a vice, heat it a bit and pretty much put my entire body weight + everything I could muster into pulling on it to get it loose. Hope you have better luck man!
(Managed to not wreck the car, barely. Stopped with about an 1/8th inch between my bumper and a sign.)
