Stripped bolts
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
On the coil pack covers on my 1jz. The allan heas are all screwed up and I need to get to the coils, and I really dont want to sacrifice the cover soooo.
What about tacking somthing to the screw and pulling it out?
Thats second to last case if chriso and I cant screw extract
Thanks
-Kyle
Big Wang Bandit
Feb 21, 2006
7,551
Probably. I just want to know is welding would be damaging, Chris was telling me about welding on an engine, could send electricity to the bearings and make them arc. Im sure well get a secrew extraction to work tho.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
OneJoeZee said:
lol. yeah, right..
matt, you just want kyle to come back down so you can molest him. :kloguck:
naw, I like em less pimple-ly. :momaru:
When are you taking delivery of the new "camry"?
P.S. Do you gays have harbor frieght up there? you can get a nice torx bit set for $4.99
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Finnon said:
can you guys like not get a cold chissel and loosen the screws with that? you know by hitting the chissel wif a hammer in the direction to loosen the screw?
kinda lol
You need something more like this...
http://buy1.snapon.com/catalog/item...group_ID=16597&store=snapon-store&dir=catalog
Or like this...
http://buy1.snapon.com/catalog/item...&group_ID=1262&store=snapon-store&dir=catalog
buckshotglass
I love all your sounds.
^ that is 100% true, I have destroyed perfectly good bearings by running current through them, luckily it was on a small sculpture, not a motor. It took me a while to figure out what happened. I do think, if the ground was right next to the place you are welding, its ok, just don't put the ground on the crank pulley. I would grind the heads off, or drill them if they were that bad, before I tried any electric welding. have fun.
