Strange thing happend
89Joe
POTATOES!!!!!!!!!!!!!!!!!
Jul 22, 2005
300
Missouri
The other day dad and I when for a drive right, So he turned the a/c on like couple minuets after start up. We Backing out and the car dies! Check engine light came on and everything. I dont know what that was but this is the first time it happend. It was fine after that, could this be a problem thats not a big problem yet?
89Joe
Jul 22, 2005
300
Missouri
No the light did not stay on after we started it back up and how do you check the codes?!?!?!?
89Joe
Jul 22, 2005
300
Missouri
Wait dont answer the code thing found out how(shaeff's sig.) :biglaugh: I'll give it a go and tell you guys what I get.
shaeff
Kurt is FTMFW x2!!!!
10
Around
woo! proof that people use it. thank you for helping yourself ;) haha
-shaeff
89Joe
Jul 22, 2005
300
Missouri
DAMN THAT WAS AWSOME!!! Ok here are the codes I got, it's ither 14 or 41. Im pretty sure it's 41 because the throttle position senser was replaced by another one which would explain the stall out when the a/c turned on and the strange jumping of the throttle. I have no idea what the heck 14 means so tell me your oppinions on the situation. Could it possibly be both?
rakkasan
Currahee!!
Fort Campbell, KY
take ypur time, if you're throwing two codes (or more), it will tell you. Sounds like it's your TPS. It's a bitch to get correct, but it's important to get correct.
89Joe
Jul 22, 2005
300
Missouri
41 Throttle Position Sensor Signal Diagnosis
Open or short circuit in throttle position sensor signal.
Trouble Area
Throttle position sensor circuit
ECU
thats it right there made sure and whent back :biglaugh:
thevork
ShoarmaTeam Member
I had the same some time ago.
It's most probably your TPS.
You can ajust it by loosening the 2 screws of the TPS.
Then you have to disconnect the connector, and use a multimeter to measure the resistances, while keeping a .5mm feeler gauge behind the dashpod.
The TSRM tells you exactly what values they should be.
here: http://www.cygnusx1.net/supra/library/TSRM/fi/FI_101.html
Be carefull when ajusting. Sometimes ajusting a tenth of a millimeter does the trick already.
Good luck.
89Joe
Jul 22, 2005
300
Missouri
Could this explain why the car seems to jump? This happens ever so often but when it dose you know when. Also could this be an electrical problem? Maybe something with the ECU? I have a spare maybe see if that dose the trick? Then about what you said Thevork, what exactly would this do? is it a way to adjust the TPS in effort to fix the idle in some way? :icon_conf
shaeff
10
Around
ECU's rarely ever go bad. i've only EVER heard of one. it's not your ECU doing it. yes, thevork has the right idea. the TPS can cause all kinds of idling problems, as well as stalling problems etc... the list goes on. fix it per the tsrm in the link both i and thevork gave you, and you'll be happy.
if you cant get the specs on it correct, then get a new TPS and adjust it with the throttlebody off the car. (much easier) when it's fixed your problem will vanish.
-shaeff
89Joe
Jul 22, 2005
300
Missouri
Well thanks for the help guys Ill give it a go sometime soon. The car sits in the driveway most of the time anyway so Ill look into doing like you said thanks again!
