Hi, i just had overheating problem. Temp raise too much on the stock gauge (dont have an aftermarket gauge) and the coolant was boiling after a ride. I test the thermostat in 99celcius water and it did nothing. It says 88c on the thermostat. I suppose it should have open to that point(leave it 5min in that boiling water and nothing happen). So i decided to change both the thermostat and the radiator since it look full of gunk trough the filling hole, so it might be semi-clogged. I had an extra clean radiator coming from an auto 7mgte so i decided to install it. Fill it with coolant and water to realize everything was dripping from the port for the auto tranny?!?! What the fuck, i read it was suposse to be for oil tranny? Look like coolant is connected to these 2 ports?
How normal is this?
How normal is this?
