Some history of the problem:
About a month ago my car started leaking coolant from underneath, first a drip, and over a few weeks, more of a faster drain. It seemed to be spread out everywhere, when looking from underneath, but seemed to start near the water pump. So I got a new pump.
Today's events:
Installed the water pump today, as per TSRM. Did a coolant flush too (or at least, just the radiator side), and put only distilled water. After starting up, for the first 10-15 minutes it seemed all was well. And then coolant started consistently dripping/spraying as seen from the undercarriage. The water pump area looks dry, but after lookign around I found the origin of a leak, as seen on the attached photo. I couldn't see the source of the leak, but the red arrow points to the direction of water dripping down from an (unknown) area of the engine. I thought it's the ISC which has a leak somewhere, but the coolant pipes connecting to it were dry. It got late today, so i'll open up the ISC area and check more thoroughly. Any other area around there that I'm missing? This is probably a really dumb question, but can coolant seep/spray/drip out of the engine area itself as a result of BHG?
BHG?
After the flush and the water pump change, the car started out as normal. But when coolant started spraying from the bottom, I saw more white smoke coming out of the exhaust. After a while, though, the coolant leak became an occasional spray, but there was no more white smoke. Remember, there was some coolant left in the system (which could have caused the smoke), but not there's almost 100% water, maybe that's why there's no smoke? Could it be that I have a BHG? I guess I'm just paranoid. I should just take it for a leak-down test. Oh and last summer I tested my compressions: it was ~145 on all six cylinders. This is a 145k engine that has been fully rebuilt 35k miles ago by a Toyota tech, although the car has been literally sitting in a garage for the past 2 years.
Thanks for reading. :1zhelp:
Today's events:
BHG?
