^heresay. You can run higher boost if you wish. If the turbos die, they were gonna die anyway. I've seen turbos blow at stock boost and high boost. Some with lower miles, some higher. My turbos are fine, no smoke and these have seen over 20psi... not on purpose but still. I had another set of turbos and those were blow when I got them. bone stock engine...
Just know that they're probably gonna die eventually anyway, so get as much fun out of them while you can?:dunno: You're not getting past fuel cut without BCC, FCD, or another ECU. I know you have a stealth ECU. If you don't want it, I'll trade you back.
