stock throtle body hp
figgie
Twin Cities, Minnesot-ah
A little math goes a long way.
calculate the internal 2 dimensional area of the throttle body. Then apply math to solve for critical velocity in that given area. Apply some more math to solve for air density and the result will be in grams/s or lb/hr.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Yes but not everybody knows that math. Not everyone has taken classes in fluid dynamics and the like.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
van supra has bean the only one to push a stock thottle that far and still no ffi as well for get the number thou 700 some thing close to 800 not sure don't remmber
figgie
Don't need to.
a short trip to google lane.
Reynolds Number (for critical Velocity) which just happens to, in one fell swoop, cover it all
http://www.engineeringtoolbox.com/reynolds-number-d_237.html
and to help along
air density = 1.225 kg/m³ (0.0765 lb/cu ft)
and since we are looking to solve for Velocity (U) for the given area...
Reynolds number is 4000 or greater
Air Viscosities
http://www.engineeringtoolbox.com/air-absolute-kinematic-viscosity-d_601.html
there
all the parts needed to solve for U
The equation is
U = V*RE/Dh
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The reality is that we don't have much in the way of real world data, because virtually nobody has pushed it that far.
Reason? Not what you would think... it's due to the screwy intercooler pipe routing. Most guys running bigger numbers scrap the intake manifold and throttle body along with the stock IC pipe routing, and move to an aftermarket FFIM, throttle body, and side to side FMIC.
beautifulpunk
11
talladega
well i am using a custom built manifold but i wanted to use the stock tb. the chassis is not a supra so bigger ic piping is not a problem. i was doing alot of r&d on the stock parts to see where in need to upgrade first. the turbo, ic,and fuel system have been upgraded. i wanted to see where my air restrictions are before i do alot of head work
