I know there have been a couple posts about this but no one ever got to the bottom of it. The ECU will cut power to a random set of injectors at or above redline. While still running a piggybacked ECU there has to be a way to cap the RPM signal much like the MAFT does with airflow signals. If I had some idea of the voltage range the injectors run off of maybe it could be restricted 5% for example raising the limit a few hundread rpm. The car might also run 5% leaner just like how the MAFT works but it could be adjusted.
The second idea would be to tap into the harness and splice the injector sets into one another so when for example power is cut to a set it will still get the signal from the set that is still being fed because the rev limiter does not cut fule completely just to a "random" set. You would have to make sure your splicing into the same set of pistons on the crank but it seems like it could be done.
I have even heard of there possibly being a wire that you can remove to disable rev limit FC but it has not been confirmed yet.
When you start running bigger turbos and higher duration cams your moving your powerband up and the rev limiter will get in your way a few hundread RPM too soon. A stock engine would not benifit from it but us higher modded guys would esp with aftermarket cranks, rods exc.
There are some ppl that will say its not a good idea blah blah blah but I dont care, I am willing to take the chance and reap the benifits if I find a way to do it.
