Hey yall, I just picked up a 7MGTE bottom end yesterday and After Tearing it down, I noticed that everything in it was really really clean. When I picked it up, the guy that I got it from said that it had a Spun bearing and it has 200,000+ miles on it.
Well, One I got the oil pan off, I noticed that the Oil Pump looked really clean (Nothing in the Filter), I started to search for the one rod that has the spun bearing and come to find out its not a Spun bearing, Who ever went into this motor forgot to Put Rod Bearings inside of the #6 rod
Pulled the #6 Piston out of the block and no Rod Bearing on either side. Pistons are in excellent shape, I checked the cylinders and It looks as though its been Honed out as I can still see the Hone marks in each cylinder and the rings are still in great shape. (Spring out really well)
My intentions were to Get this Engine Bored out and install .020 non forged Pistons, Since this engine has already been through and everything is Factory Toyota, would it be better to stay with the Stock Pistons? Ive heard that stock Pistons can take alot of boost and most of the time they are better than most of the non forged Pistons that are out there.
Do .020 Pistons really make that much Difference if they are non forged?
Im going to put my new Crank into this Block with my rods and Bearings, All I thought about doing is just installing those Pistons on my Rods, Doing a Light deglaze of each Cylinder since Ive pulled all the pistons and cant remember which cylinder they go into and re-assemble everything.
Any Recommendations would be greatly Appreciated
Robert
Robert
