stock mk3 boost valve....?
89boosted
88boosted
Jan 3, 2008
58
Morrison
does a stock mk3 have an internal swing valve with factory boost regulating solenoid, or is it not equiped with one? type 1, 2, or 3? , im trying to hook up a greddy profec b boost controller and i dont know what type of solenoid valves mine has, could someone maybe check it out on greddy.com, then go to tech/support, then profec b boost controller and tell me what directions to go off of, id appreciate the help, thanks
89boosted
88boosted
Jan 3, 2008
58
Morrison
so how would you hook up an electronic boost controller? what hoses connect to what? sorry im a beginner i dont know much
GrimJack;1054232 said:
Stock Mk3 has no boost control - wastegate actuator is pressure activated and plumbed directly into the turbo outlet.
RiyadYar
384
NY
i have an old apex-i super avc-r .. it uses a pressure sensor and solenoid valve which i dont have i understand were the solenoid goes but were does the pressure sensor go ?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
It connects to anything in the intercooler pipes that is under pressure from the turbo.
Apr 6, 2005
339
Alpharetta, GA
If you can write in English, then you can read in English.
Goto the Apexi web site (http://apexi-usa.com/ ) and download the PDF instruction manual and read it thoroughly. :3d_frown:
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Look at the turbo, there should be a small vacuum line running from the compressor housing to the wastegate actuator.
Remove this line, hook the compressor housing up to the NO port on the solenoid, and the wastegate actuator to the COM port. Leave the NC port OPEN (not capped!).
I believe this is described in the Profec B manual.
