stock injectors
Kazooie
DK
how many horsepower can they hold.
and how much boost
i have
walbro 255
blitz access ecu
trust 3" dp
HKS twinturbo
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I would assume if it's got a good tune on it then you could get some good numbers... what are you shootin for?
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
Kazooie said:
400-450hp
you'd be getting close there I think... but someone on here might have done it... I'd recomend getting 550's if you can b\c I'm not so sure that the stockers can handle that hp...
Jspec7m88
1,583
Nappy City
If you are shooting for 400-450, you need to be going AT LEAST 550's. With over 400hp, running 440's would be pushing it on the edge, therefore losing performance. To answer your question, YES, you could do it, but its hard telling what kind of fuel problems you would begin to run in to. Just go with 550's and you'll be plenty happy with your fuel setup! It'll be worth it in the long run.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
I didn't see a fuel management on the list, so 550 will not work. Tuned ecu, HKS turbo, and with 440's will be close to that #s. HKS cams will also be an idea.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
just spend the money and get a maft setup with 550's... or even maft pro if you don't have a budget...
I
itr206
Guest
WOW is all I can say. :nono:
