stock HG max torque rating
Tire Shredder
569
Oshawa
Hey guys,
I'll be installing a stock-style Head gasket on my my 7mge after resurfacing the block and head and will be using ARP studs. Can somebody tell me the max torque rating I should be using? I've read about info on this for the metal headgaskets but not for stock headgaskets...we all know the toyota specified rating is far too low.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I went with 75ft lbs on mine. I suspect under that pressure the HG will crush/compress a little more then specified. I believe the Toyota spec for the HG once installed (according to their headbolt torque specs) is 1mm, I may be wrong on that.
