Stock Fuel Pressure
Justin
Speakers?
Spokane, Wa
I just got my AFPR in... I have a Walbro, J-Tube bypassed, and the FPD Bypassed. Stock injectors, until I get mine back from RC Eng getting them cleaned.
1. What's stock fuel pressure?
2. What's ideal fuel pressure? What should i set mine at?
I searched, but I'm lousy at it and can never find what I'm after....
jdub
Feb 10, 2006
10,730
Valley of the Sun
Justin said:
33-40 psi, that's an awful big difference. Is there a benifit to 33 or a benifit to 40?
My Lex/550 set-up seems to run best at 25-27 psi vac on.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Yes...as you add power, vac reduces and turns to pressure under boost ;)
Can't find the ratio for the stock FPR...the Aeromotive raises pressure 1:1 to boost.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Looked at another way the Toyota Type A fuel system used on a stock Supra keeps the sum of manifold pressure and fuel pressure at a constant 36 psi ie; they'll always be a delta P of 36 between them. If this were not done injected fuel would vary with manifold pressure for the same fuel pressure and injector duration.
