Make sure you have the right type of flanges on the test pipe first obviously, but assuming that's true, it is just a matter of lining up the holes and bolting it up. Test pipes are made to be the same working dimmensions as a cat for specifically that reason, so you can bolt it up in place of the cat. If your cat back bolts up to stock, no reason why this shouldn't too.
