Stock electric double fans problem.
InFrnt0fU
Lurking Supra Socialite
The dual mini radiator fans don't work. I just took it off, replaced the two fans(one was damaged, one was missing) and now it doesn't work? I have tried switched the plugs both ways but have had no luck. I had to use WD40 (let it sit overnight) to get the rusted screws off from the broken/missing fan, could this have done anything electrically?
Thanks.
jdub
Feb 10, 2006
10,730
Valley of the Sun
You should be able to test by pulling the connector off the sensor and using a wire to ground the connector against the body or the neg terminal on the battery. Doing this should make the fan run ;)
