:1zhelp: anybody know how to degree stock cams? using the 3 holes in stock cam gears? I had head cut .020 and block cut .020 and want to make sure cams are set to factory spec. I saw post saying intake open at 6 btdc closes at 50 abcd exhaust open 53 bbdc close 3 atdc. How is this measured ?Or do use 050 lift and find centerline? With .008 exhaust lash my exhaust cam opens at 123 bbdc and closes at 20 atdc. When lash changes so does opening and closing of valves. With .006 lash my intake opens at 15 btdc and closes 100 abdc? help
i
i
