Stock cam gears noisey
cmoney_kps86
pittsburgh PA
racerpage;1078814 said:
Anyone run into this? They are chattering but bolts are tight. Made sure it wasn't a valve lash problem or rod knock.
I know that the clicking / ticking noise are the injectors ...but chatering .... dosnt sound good, i would pull the valve covers off and check and see if you seal wore out, or if a cam is cracked.??
racerpage
Supra Drifter
Jun 15, 2007
94
Baltimore,Md
Allready did that and rechecked the valve lash again.
