Stock BOV, vent it to the atmosphere or not?
confusatron
24
Chicago, IL
I was wondering if you vent the stock BOV to the atmosphere, would you hear it, would it sound decent, and if you plug the vacuum line to the intake manifold, would that allow it to function ok? Would this cause problems, or is it a good thing to do? Thanks.
shaeff
Kurt is FTMFW x2!!!!
10
Around
as indicated, the stock BPV is designed to fluctuate between open and closed at idle. unless you want stumbling problems, vaccuum leaks, and a world of chasing your tail headaches, don't do it.
by the way, a quick search would have yeilded you this same answer. it's in the reference section. ;)
-shaeff
