stock 1jz turbos
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
will the stock 1j turbos bolt on to a 1g? they use the same type of setup and the turbos are almost the same but does anyone have know if this would work or not?
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Most people don't know jack about the 1G. You should be an insider for us and find out EVERYTHING you can about it, and post it on this forum. You probably won't get many people who are interested in it since the 7M-GE has comparable horsepower and more torque than the 1G, AND there is no swapping involved; the 7M-GE comes in the cheapest MkIII Supras you can get your hands on.
I don't know if the 1JZ turbos will fit on the 1G, but if they are semi-custom and need a little welding/massaging, and you don't mind going with a little a custom work, you might consider getting a pair of US Spec 2JZ turbos instead. You can set them to work in parallel just like 1G/1J turbochargers. They are responsive enough for a stock 2JZ [280hp] and capable of flowing enough for the top end of BPU++ etc [450-500hp].
For questions like this, most people here don't know, BUT I would seriously consider checking out toymods forum online. I believe it's an Aussie site, but that's really what you want - they actually get JDM cars and some of those Aussies are creative as all hell when they find a project in the junkyard.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i was just curious if they were the same size bolt pattern so i could just swap them out. i was a member of toymods before they changed the address to it.
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
why do that? If you going to go custom, do a single turbo upgrade. We talked about this josh ill help you build a mani!!!
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
7mge 200 hp 188tq
1ggte 210hp 203 tq
i still think the 1g is a good choice and i have beaten several na supras and 1 or 2 turbo supras
drunk_medic
Woodstock, GA
eviltwins said:
7mge 200 hp 188tq
1ggte 210hp 203 tq
..IF the version of 1G you got happens to be the latest version. That's the highest hp/torque number that came out of a 1G. That's like saying "My MR2 has higher stock horsepower than your Supra". "How?" "Oh, I put a 3rd generation J-Spec engine in".
