Stock 1JZ oil pressure sender
ToyoHabu
261
Huntsville, Alabama, United States
Since the 1JZ uses just a light for low oil pressure indication, does this mean the sender is just a on / off switch ? turns off when say 6 psi is reached ? Or does it work differently and it could be used to power a guage.
935motorsports
San Diego, CA
It is an oil pressure switch.
You need to re-use your old 7m sender, via an extended line or elbow to help it clear the AC bracket.
You will use the same yellow/black wire that goes to the switch, which matches the yellow/black wire in the dash for oil pressure.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Any idea where I can get a pipe to extend it??
tsuper92
supra addict
Apr 7, 2005
1,376
mass
use the rubber upper brake hose off your clip.it will thread into the block and the sender will thread into it
becauseican
Vancouver
www.bicperformance.com
The sender hole in the block is threaded with 1/8 BSPT which looks like pipe thread but it is different. I used an autometer adapter, 1/8 bspt to 1/8 npt part number # 2269, then a 1/8 pipe thread to -4 an adapter, then to a short 8-12" long premade braided hose then another -4 an to 1/8 pipe adapter then screwed in the autometer oil pressure sending unit.
Using the hose allows you to put the sender where ever you want it, because there is no room to put the Autometer sender in the stock location. I ended up zip tying the sender to the hard coolant pipe just behind the oil filter unit, I will try to find some pics of the setup.
here is a pic, http://bicperformance.com/pics/bicoilpressurelin.JPG
tsuper92
supra addict
Apr 7, 2005
1,376
mass
zoonwen said:
do you need to ground the sender to work if i use the brake line.
i'm not sure if it needs to be grounded.i grounded mine for the hell of it
zoonwen
1JZ Supra
Apr 27, 2005
199
Denton, TX
Thanks , thats were i figured it would probably go =) I ended up just using a break line to use the oil pressure light switch hole and yes I had to ground it for it to work.
itr.00-1282 said:
it's a big hollow bolt that bolts the oil filter housing and oil cooler to the block
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
How do you go about grounding the sender? I attached my sender into my greddy oil filter relocation kit, I have continuity and power and the damn thing still wont work. Maybe I just have to ground it then?
Feb 24, 2006
187
Los Angeles
when u install the 98 tt union bolt, do you need to bend that coolant line the connects to the oil cooler/oil filter or will it clear it? b/c i bought one and i haven't had the urge to install the thing since it looks like it wouldn't clear enough for the sending unit
