stink a/c
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
A good practice I've been told will keep the smell from occuring is to run the fans with the A/C off before turning the vehicle off. Not sure if it is any good to you once the smell has really started though.
mista_sup
211
atlanta
where is that drain? i looked and ????
jetjock;1306267 said:
Mold in the evaporator. You can buy a product made just for the problem but spraying Lysol into the fresh air inlets should clear it up. Check to sure the evap enclosure drain is clear too...
