the caps in my ecu blew causing my car to misfire like crazy, i got it fixed at full throttle in Queens NY and i plugged it up today and it started up just fine and i thought all was well the it started to misfire again. it wasnt nearly as bad as it was before, it is wayyyyyyyyyyyyyy better than it was before. its jsut a slight pop at idle, whn i rev it up it goes away. maybe it could be a fouled spark plug? im not sure, but when i pulled the plugs they looked good. i got the NGK iradium plugs in there right now. not sure what else it could be.....
