Its bad...
Feels like fuel cut, but it isn't. I get no code 34, and the afm signal never goes above 1100 hz. Happens at anything over 2 psi of boost, starts hesitating and surging. A/F stays correct, no codes. It was throwing a 52 so I took the entire harness apart and redid the knock sensor wires with high quality sheilded cable, and I made sure to ground the shielding. I swapped out both knock sensors and the code is gone.
Timing is 10deg BTDC. If I neutral rev, at a few different throttle points I get a miss/ hesitation before it will rev.
Any ideas guys? I'm almost to the point of pulling the engine and parting it out
