Out of the blue some people found out that Comp Cams has a valve spring kit for the chevy v8 that fits our 7m heads.
http://www.powerandperformancenews.com/store/merchant.mvc?Screen=CTGY&Store_Code=CC&Category_Code=SPRNGSI
Part # 975 ( the - dash then the number means how many in the package)
so 975-1 is ONE spring, where 975-12 is TWELVE SPRINGS in a package.
I am ordering mine this week. The seat pressure is 60 lbs vs. the stock valve springs of 32lbs ( correct me if I am wrong guys).
This in turn keeps the valve from floating, or when the motor ( as IJ noted ) is accelerating faster than the valve spring can keep up...the valve "floats".
Not a good thing....though our motors are NON-interference, so even if the timing belt breaks or you float some valves...the probablitiy of your valves slamming into the pistons is far less if not any.
All in all, the comp cams valve sprnigs are an insanely cheap upgrade for the money and can save you a pain! But more often than not will keep your motor from winding out those 100+K mile springs that you have in there.....
Remember, the older the spring, the less the seat pressure is....they SAG....
-Jonathan
