how do you remove the Instrament Center Cluster Finish Panel so that i can remove the radio/stereo? does it just snap on and off, or is there hiden screws or clips i should know about before man-handling the whole thing off?
There's a screw by the driver's right leg, one below the hazard switch, and 2 in the ashtray's bay.... you'll also need to remove the top two which hold in the ashtray's metal top piece. Then it snaps out.
I have parted 5 MKIII's, and just today on MKIII #6, I just found that screw under the hazard switch.I guess it never gets put back in, if ever taken out.
