Hey guys,
So today I decided to install my stereo repair harness onto the existing bundle of chopped up wires coming out of my center console. Everything was going fine until I finished splicing all of the wires coming off the harness and found these two wires; one is pink with a blue stripe, the other is black and red which I know might be the power antenna wire.
I'm not currently running a power antennae so I don't mind leaving this one as is. The repair harness I bought was like this one http://www.ebay.com/itm/TOYOTA-Supra-87-88-89-90-OEM-Reverse-Radio-Wire-Harness-/260762240810. Any ideas on what this pink and blue wire might be? I used these two references to help me out with the wiring.
And
1987 Toyota Supra Stereo Wiring Information
Radio Battery Constant 12v+ Wire: Blue/Yellow
Radio Accessory Switched 12v+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Stereo Antenna Trigger Wire: Black/Red
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
I'll be hopefully finishing up this job tomorrow so any advice/help that I get before that will be much appreciated!
Thanks in advance
And
Thanks in advance
