sometimes it will yank off, but a steering wheel puller is the easies way. other way is using a brass drift, and make sure it is brass, and put your knees behind the wheel and put pressure on it, then using the drift and a hammer, hit the shaft and the wheel should pop off. if you dont use a brass drift you will damage the threads
