The tsrm says to remove the steering knuckle i have to remove the upper control arm from where it bolts to the subframe and remove the lower ball joint from the bottom arm. then dissasemble on a bench. is this the easiest way? i have wd40/plus gas'd everything up that id need to undo if this was the case i just thought id check here to save myself any heartache/ unnesesary work.
also ive heard plus gas is a whole load better than wd40 so since im going to be droping the tank out to fix my leak can i buy plus gas in a spray can? the plus gas i used is like about 35-40 years old (my dad bought it when he was an apprentice mechanic lol)
cheers all
oh btw not sure if plus gas is available in the us. i cant find anything called pb blaster over here.
cheers all
