static balancing enough?
FullNelson
574
Coastal Georgia
Well right now my motor is off at my machinist, and the bottom end is being dynamicly balanced to IIRC .5 gram among other things. If i choose to change my rods to somehting like Crower or Pauter, somthing that is statically perfectly balanced, would this throw off the dynamic balance?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Pauter rod weight is pretty consistent, but those weights (and pistons too) need to be factored in when balancing the crank. So does the dampner and the fly wheel/flex plate.
Thought the dampener and flywheel/clutch doesn't matter as long as their zero balanced seperately as our engines aren't externally balanced?
jdub
Feb 10, 2006
10,730
Valley of the Sun
It "shouldn't", but "should" is right between "F" and "U" in the alphabet ;)
I always do it...call me anal. It doesn't cost anything and it balances the entire rotating assembly.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Well, if the damper and flywheel or flex plate is already zero balanced (as they should be), it doesn't really matter. But, you are correct..you do not have to have these components attached. When I had mine done, I had the ATI damper and flex plate attached...I'm not expecting a failure of either...I wanted the rotating assembly to be as close as possible. The crank was also checked without these and was in spec. My CP pistons and Pauter rods all weigh within 1/10 gram of each other.
Balancing a crank is always a compromise...the dynamic forces acting on a crank include both reciprocating and rotating weight. Rod to stroke length ratio, piston ring drag, RPM, engine power output, etc all have an effect.
