Starting up for the first time - issues
smokey
129
Melbourne Australia
Oooooooookkkk where to start
Obviously its a 7mgte, it's just had a rebuild and it went from a standard setup to a little more than that.
Mods-
450hp garrett turbo
bosch 040 fuel pump
new manifold
external wastegate
sard fuel reg
front mount
there is more but not really important.
now to the issue
we finally got it all wired up to start for the first time (in over a year) and it would crank but not fire. the wiring loom is a bit of a dodge job (few added wires by the mechanic for reasons unknown to me)
so when i checked the fuses, the EFI fuse was blown, replaced it and as soon as you crank, pop, fuse goes again. this lead me to check the ECU.
It had several fried resistors due to some kind of surge going back into it.
Currently saving up for full aftermarket management (wolf3d or microtech) but i'm also thinking about buying another loom/ecu just to run it in and get it on the road as its been far too long.
now two questions
1: would it be safe to run in with these mods? no nasty things can happen (enough have happened so far in this build)
2: what would be the cause of the frying of the ecu and subsequent failure to start?
I appreciate as much input and advice that you guru's can provide
Cheers
Smokey
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
did you check your headlight fluid?
lol nice to see u make it over here smokey. Im sure you can get your problem sorted by some of these fellas.
Smokey: :( If it were me I'd dig up an unbutchered Loom and ECU as who knows what "Genius Mods" have been done to your old one......
The wiring on these cars is a nightmare at the best of times let alone when a rocket scientist has been at work!
(where in Melb?)
smokey
129
Melbourne Australia
SE suburbs, out near dandenong morrabbin area.
cars currently sitting in a workshop in dandenong collecting dust
oh dont worry the dude who had it before me was a complete, for the lack of a better word, cock head. car lasted a week before the BHG - camiweld was found in the engine *Good work by the inspectors who went over it*
toml
203
Adelaide, Australia
Hey smokey, still having problems mate? :(
I'd be trying a decent loom/ECU too.
Damn, I was over in Melb a couple of weeks ago for the F1s, should've come seen you guys. :)
smokey
129
Melbourne Australia
haha wouldnt be seeing much, bunch of stock mkiii's :p
except a couple on here from melb and mine there aren't many done up that i've seen (hiding in the trees perhaps)
