my car startes fine until last night it just crank and crank after awhile it started now its dead again just crank doesnt want to start could it be the igniter thats bad.
That would be either of the problems we just told you about.
If the car doesn't see signal from the cps, you won't have spark.
If the car doesn't have a good ground on the CPU / EFI ground harness, you wont' have spark.
ok if its my CPS that is causing my car to die, how do you fix that, car wont start once in awhile but when wiggle the CPS wire car starts, whats the fix to this problem.
