Starting problem
hellraiser456
130
canada
when i go to start my car in a mild warm state...been sitting for a bit but not to the point the engine is cold..it will turn over and start right away but as it comes odwn to idle it will sdtart to stall...so i have to rev it a couple of times and after that it usually idles just fine...especially once you start moving.
also cold starts it seems hesitant to start...it will turn over...and instead of firing right up it will just slowly start up...like it will catch at 500 rpm and slowly make its way up to the 1400rpm or w/e it is when in cold start mode..
only code i have is 52 and im told that i need a new knock sensor...could it be related or could it be because of a BHG and a slightly low compression somewhere...i don't have a compression gauge handy atm so if it is a BHG, what are some other symptoms that i should be looking for
if it isn't a bhg then what else could it be?
could it be a bad O2 sensor because i seem to be guzzling a little more gas than it should...in my opinion at least...
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
Believe it or not, it could simply be a boost or vacuum leak.
Leaks can make your car do some craaazy things.
Is your car smoking at all or more than usual?
