supras,
I just got my car running with maftpro, runs real good. Drove it for four days now have problems.
I turn key, nothing happens, if I keep key turned to on I blow the am1 fusible link that is 40amps.
I know my battery is good.
neutral safety switch tested for contonuity is good.
i can start the car by applying 12 volts to the brown connector on starter with the key on.
the brown connector is not getting any juice from turning key.
when this happened i discovered the battery cables werent tightened down after the maftpro install, so i tightened them and charged the battery assuming bad battery but now i have found this perplexing.
any input?
thanks
peter
any input?
thanks
peter
