starting issue
wildfire0310
64
Dacula, GA
ok so i finally put the supra back together.. well at least enough to be trying to start it. (exhaust isn't all the way on and I still need to bleed the clutch)
Here is my problem, the car will crank but won't start.
Here is the work I did when the car was been worked on.
Pulled the tranny, to replace clutch hub
Pull the valve covers and painted them
replaced a missing bolt on my turbo manifold....
Tried to start the car and nothing,
notice the ground on the coil pack was iffy so I replaced it
noticed the O2 wires were bad so I slice around the connector(one wire at a time) and nothing.
Did a search on here and found about the CAS, looked at my wires and saw they were falling apart.
Sliced around that connector and still nothing.
I swapped batteries with my oddessy that was on my shelf, either battery needs to be jumped, but the oddessy has a stronger crank to it.. When I swap batteries I had to replace the battery terminals so they are new..(one of the main reason I swapped batteries)
I notice there is still a check engine light... not sure it still the old code 11 or a new code... can't find the diagram of where two pins to jump to pull the codes anymore....I know this will help the most..
Any help would be great...
As soon as I can figure out how to pull the codes again... I will get them also...
Thanks
