starter progress pics!
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i finally got down to the dealership today! after a week of having my supra sitting in the garage, im ready to get it back together again.
had to order some gaskets and a few hoses to replace what i found on my way to replacing the starter. got the rest coming from RockAuto, we shall see how their quality control is.
take a look at the pics, and yes, i know i did it the hard way.
Clip
Oct 16, 2005
2,738
9
Virginia
Yellow 13 said:
lol, Damn you ripped it apart getting the starter out.
not only that, torn and shredded too!
and if you have to ask about the hammer, you must not have worked on the supra long enough. j/k :rofl:
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
you took the intake out wow you miust have be arm's to have to do that
an easy trick for next time is to cut a 14? if remmber right in half or use stubby wrench
but the best part is get rid fot he egr were you are there then next time it be so much easyer
that egr suck's for gettign at that shit
Clip
Oct 16, 2005
2,738
9
Virginia
any ideas to relocate the egr, nash? and yeah, the intake came out with the rest of the engine in place. i was to the point where i was going to pull the whole damn engine/transmission cause the intake didnt wanna come off. luckily i got past that :D
NashMan
Aug 5, 2005
4,940
17
Victoria BC
relocate man you have to invent the wheel on that one eather dich it or keep it
if you have smog out there just keep the cat you should be fine if you have smog
MKIIINA
Destroyer of Turbos
Plano, TX
relocate the egr to the trash can! glad to see you are getting it back together and are doing proper maintance.
Clip
Oct 16, 2005
2,738
9
Virginia
mrnickleye said:
OK....is everybody ready???????
The cover in question is part of the EGR (exhaust gas recirculation) system.
Remove the bolts, then the cover, and clean it all out, cause it will be full of soft carbon crap. There is a gasket available, or just use a little sealer.
The way it all works is this........
The exhaust gasses come out of the head (inside, thru passages)at the #6 cylinder, pass thru the 'egr cooler' (which is actually just a hollow space under that cover on the back of the head, by the firewall), then on to the egr valve.
From the valve, the gasses pass thru a pipe to the intake manifold, then thru a passageway in the intake manifold, over to that little chamber under the cover with the 4 bolts. From there the gasses are allowed to flow into the intake manifold so that they can enter ALL 6 combustion chambers.
A properly operating EGR system will actually give you more HP's, and better MPG.
How, you ask???
By helping to control ignition pre-detonation (pinging), allowing you to run 87 octane fuel (cheapest), and with no pinging, the knock sensor won't tell the computer to retard the timing.
you guys sure about ditching the egr system?
